On CA-US plan, question on the international long distance while in US
VK
On CA-US plan, will the international long distance to non-CA/US numbers work while in US?
DennyCrane
No. The Canada/US plan only includes calls to/ Canada and the US while in the US. International long distance add-ons are incompatible while in the US.
It's similar at Telus too. Their Canada/US plans only include calling to Canada and the US while in the US. Calls to any other country incur roaming charges of $1.60/minute (at Telus; with PM it just doesn't work).
Grand_Total
For the 300 International Long Distance Minutes add-on the fine print states explicitly that "Calls must originate from Canada".
No such text for any of the other add-ons, but I would not rely on being able to make a call to anywhere other than the US or Canada while out of Canada.
Sansan
Probably not, but only 1 way to be certain... when you get there try it
kb_mv
@VK Not often do I see a question that hasn't come up (or is at least new to me). I think you should contact customer service at the link below. Someone may pipe up in the meantime with current experiences.
@VK  That’s a good question . But it’s my believe the long distance mins are just for making from Canada to abroad
