Number transfer
Jw65
I need a request sent to my old provider for a number transfer
7 REPLIES 7
eswar
directly buy a plan in public mobile, it will guide you to buy a plan, transfer or take new number and details required for port will be asked, like mobile imei, old number etc
it is seamless and free
Jw65
Thanks
@Jw65  yes, porting team can help.  But they are closed for the night, call tomorrow morning
Abheer
Oh, in that case, you can call the phone number which @softech sent you in your mail.
Jw65
I did but I didn't reply in time and its bell so I need it sent agsin
@Jw65
did you submit a porting request yet?
If not , you will have to login to My Account, go to Profile page, click Transfer Number and enter  your phone number and old provider's account number
if you already submitted a request, and just need to re-trigger the process, There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
Abheer
Hi @Jw65
When activating, on your old SIM card, you should receive a message which you have to reply "YES" to complete the port. Who is your old provider?
