06-23-2023 10:46 PM
If you are connected to public mobile network why am I not receiving the 6 number code that I am told is being sent to me. I click resend and it doesn't send. I need this to get full access to my account. Anyone have any ideas?
06-26-2023 01:36 AM
No, I am still having issues with my phone and any account that uses Google or a password, since whoever it is has access to what I'm seeing on my screen. I ordered a new SIM and hopefully it'll be here by Tueaday at the latest. I still have service and access to PM account. But settings keep getting changed for apps (security and anti-virus app had all permissions removed several days in a row) and verification codes are coming from random landline numbers instead of proper sources. I will confirm SIM card number in the morning.
Emails not showing up in inbox.
Contact numbers being changed or altered.
Screenshots being deleted or corrupted so no longer viewable.
Passwords being changed.
06-24-2023 01:25 PM
Have you changed phone numbers by any chance? It seems there is a problem in that if you change/port in a new phone number the system may keep sending the code to the previous number unless you change it in your Eversafe profile
06-24-2023 08:54 AM
@SarahSz is your issue resolved now?
If not, then you have no PM service now? Can you still login to My Account?
The Facebook issue could be compromised via other means, unless you also notice your PM service is gone around the same time
and if you can login to My Account, check your Profile page, there is a sim card number there, check if the sim card number is the same as the one you are using now
If you need further help, provide us more details
06-24-2023 07:55 AM
SIM card may be compromised. Geek Squad at Best Buy can have a look to confirm for you. I just had to order a new one. Verification codes not showing up or being sent by strange telephone numbers. Lost access to Facebook nearly 2 weeks ago and still cannot recover because contact info has been changed. Not sure how SIM would've gotten compromised, same one for 5 years.
06-23-2023 11:04 PM
@JakeQuenten if you tried all the workarounds above and nothing work, PM support will be your friend. Message them :
06-23-2023 11:00 PM
I did not get an email saying I am locked out. It literally just wont send me a text when other can...
06-23-2023 10:54 PM - edited 06-23-2023 10:56 PM
@JakeQuenten check your email did you get mail from PM saying you’re locked out ? Is so you will have to wait n hour before trying again . And when you do try incognito private mode or different device . Also if trying on website try on app
If issues persist please
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
06-23-2023 10:52 PM
@JakeQuenten are you in the process of activating new account?
Another potential workaround
06-23-2023 10:51 PM
It will not give me that option unfortunately. Its weird. I can send and receive texts I am just not getting the text from Public Mobile to confirm my number
06-23-2023 10:50 PM
It does not currently.
06-23-2023 10:48 PM
@JakeQuenten Try putting in the wrong code a couple times does it give you option for email instead
06-23-2023 10:48 PM
@JakeQuenten are you in the process of activation?
and try this: On the screen it is expecting you to enter the code, click Resend code and then choose Send email
