11-26-2021 04:40 PM - edited 01-04-2022 05:05 AM
I am not able to process payments using voucher. My plan got expired today. I have been trying at multiple stores, but payment is not getting processed.
11-26-2021 05:59 PM - edited 11-26-2021 06:38 PM
@Rajukrish : What you have to lose is your time. Those suggestions waste it.
Edit: I'll update this when I see my doctorsim test. IIRC it doesn't work
Edit again: doctorsim works. Just might take a little longer than momentarily.
11-26-2021 05:46 PM
Yeah contacted them now. Let's see. Thank you. Shall update on the solution.
11-26-2021 05:44 PM - edited 11-26-2021 05:45 PM
I have no experience with doctor sim but online top up payments can take several hours to be applied. Time for you to contact customer support. I recommend a private message and include the pin codes from all three vouchers. Taking photos of the vouchers are preferable to ensure their are no transcription mistakes. The CSA will be able to check that they are valid and load them onto your account.
Send a private message... Contact the CSA's (formerly moderators) by sending a private message and leave a detailed message explaining your issue and the info to verify your account by including the following information:
If you cannot remember your pin # include at least three ( if they apply)of the following:
The average wait time is 2 to 4 hours but be prepared to wait up to 48 hours for non urgent requests. Current wait times are about one hour and are probably even less as I have had some very quick responses in tne past week.
Keep an eye on your private message box the envelope icon next to your avatar for a little number to pop indicating a message from the CSA's (formerly moderators.) Responding promptly will speed up service times.
Do not post any of this info in the community only in your private messages when communicating or contacting the CSA/Moderator_Team.
  To send a private message to the CSA's (formerly moderators) click below
: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
11-26-2021 05:37 PM
Now I tried top up at doctorsim. I lost my money. It didn't get recharged
11-26-2021 05:36 PM
It says it is unable to process my the request. It happened with all the three voucher numbers that I tried.
11-26-2021 05:35 PM
please i'm say just try it is nothing to loser and maybe when the refreshing network, is will work but i say also if not working contact to CSA,
11-26-2021 05:29 PM - edited 11-26-2021 05:31 PM
@Anonymous
How is rebooting the phone and reseating the sim card going to fix an issue with loading a pm voucher onto the system to pay for service? The two have nothing to do with each other?
These are unnecessary steps that will not help you load your vouchers. If your attempt to load the voucher via 611 fails please tell me the message you recieved when it was rejected.
11-26-2021 05:28 PM - edited 11-26-2021 05:30 PM
@Rajukrish : Redeeming vouchers has nothing to do with the device.
611 is usually pretty solid for redeeming them. It can tell you your balance in case it did redeem along the way.
11-26-2021 05:28 PM
@Rajukrish wrote:Trying since yesterday night 😔
If you don't want to do the instant top up at canadiantire, then contact CS to see if they can help:
Open a ticket via:
https://widget.telus.tiia.ai/publicmobile/publicmobile.html (faster response time)
Type "ticket" > Click "Contact Us" > Select your issue > "Click here to submit a ticket↗"
or send a private message to:
and describe your issue. Include your name,phone #, account #, Email address,4-digit PIN to speed up authentication process.
After sending the message, watch your community inbox for their reply.
11-26-2021 05:23 PM
@Rajukrish wrote:Ok
i hope it will works if not go to my OP instructions to see how to contact CSA,
11-26-2021 05:20 PM
Ok
11-26-2021 05:19 PM
11-26-2021 05:18 PM
11-26-2021 05:16 PM
Ok maybe you made an error when entering the 12 digit pin #. If it has been an hour since your last try then call 611 from your phone and try again. Report back your results.
11-26-2021 05:10 PM
Yes
11-26-2021 04:59 PM
@Anonymous
London Drugs vouchers are immediately valid upon purchase. I have yet to hear of an issue with adding them other than the OP. Some additional instructions may be all that is needed to help them with their issue.
Does your pm London Drugs voucher look like the one I gave you a link to?
11-26-2021 04:56 PM - edited 11-26-2021 04:57 PM
* some vouchers take 24 hours to activate,
you can call 1 855 4PUBLIC and add your voucher PIN
or call *611
close all Browser and do clear cache and cookies for any Browser,
and try open one Browser incognito mode,
You will usually find it at the top or bottom of the receipt. To top up your account with a voucher, log into your Self-Serve, account, click on the "Payment" tab, then "One-time payment". In the form that appears on the next page, click on "Payment voucher" as the payment method, enter the voucher code below, then click "Submit".
if you can't fix it you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
they can solve your issue, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
Good Luck..
11-26-2021 04:53 PM
The London Drugs ones should work right away. Which 12 digit code have you been using? Keep in mind you can only try two attempts to add a payment before having to wait an hour before trying again. Use the PIN# as it appears in this link...
11-26-2021 04:49 PM
I have been trying different vouchers since yesterday. I tries two from London drugs and one from a Telus stall. It didn't work.
11-26-2021 04:46 PM - edited 11-26-2021 04:49 PM
Did you purchase a pm voucher that fully covers your plan amount? Some retailers pm vouchers are not immediately valid. Vouchers purchased from 7/11, SDM, London Drugs and Shell stations are all immediately vaild upon purchase. Dial 611. Then press (1) and (1) again and enter the 12 digit pin code #. Once accepted your plan/service will automatically reactivate. Reboot your phone if necessary.
Edit:
You may find this thread helpful:
Nice edit.😃
11-26-2021 04:41 PM - edited 11-26-2021 04:44 PM
@Rajukrish wrote:I am not able to process payments using voucher. My plan got expired today. I have been trying at multiple stores, but payment is not getting processed.
Try using online top up like recharge.com or https://www.doctorsim.com/ca-en/topup-phone/ or instant top up at canadiantire gas bars.
Some in-store vouchers are not activated right away.
