09-04-2019 05:32 PM - edited 01-05-2022 08:47 AM
09-06-2019 12:14 AM
@Jimmysincere wrote:Im not abel to enter my pin to my account. Get error message
The only way to reset account PIN is to contact moderators.
Voicemail password can be reset using self serve.
09-04-2019 06:39 PM
@Jimmysincere The PIN is only used when you use Public's IVR system by dialing 611 from your phone. Is that what you are asking about. If yes, the PIN was setup by you during activation. Check you texts from Public it should be in a text.
09-04-2019 06:13 PM
Are you referring to your voicemail pin or account pin? Where are you trying to change it and what is the error?
If it's the voicemail pin from the main menu press 4-4-1.
I've read that account pins can only be changed by the mods, so if that's the case check out this link for info on how to contact them: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/The-Public-Mobile-Moderator-Team/ta-p/...
