No texts in or out
TLabecki
I changed my cell phone number to Public Mobile from Koodo 2 weeks ago and haven't had texting ability since. Everything else seems ok though.
10 REPLIES 10
TLabecki
Yes, I have created 2 tickets but no response.
@TLabecki
handy and myself are just customers like you and not PM support
from what you mentioned, it looks like just a sim provisioning issue and it is an easy fix for PM support.  Please open ticket with them if you have not done so:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗
TLabecki
Can you contact me again please. Issue still not solved.
@TLabecki
is the line working now? did you open ticket with PM support?
TLabecki
I am unable to see your previous responses..
TLabecki
No phone calls either..it's my disabled daughter's phone. She did get a text from Koodo re the phone number and responded yes to use old number but unsure if did it in time...
@TLabecki you sure you are getting incoming calls?  Especially, can you get calls from non-telus phones, like Rogers or Bell?
TLabecki
iphone 11
Using an e-sim, tried to use same phone number but never got text from Koodo about that which I understood should have happened...
Dunkman
@TLabecki
Which model phone are you using?  iPhone versus android?
Try a network reset of the phone. Note: this will erase any saved Wifi passwords
You can also try your SIM card in another working phone.  That would help determine whether it is a hardware issue versus PM service problem.
@TLabecki
send  a  private message   To CS_Agents
