No service
GordogSull
I finally got my phone unlocked,now it says no service and incoming calls go to mailbox.
It’s been a frustrating week and still no service even though my account shows active,my phone is an iPhone 4S which i stated before ordering my SIM card.
12 REPLIES 12
Moved:
@GordogSull
It is still good to test the sim on another phone.  Tru to borrow one from a friend
And you opened a ticket witj support to confirm if your new sim  was setup on the system properly?
GordogSull
Thank,it’s not black listed I just checked.
jlovesedmonton
Try to restart your phone and try again
@GordogSull
you may not but does one of your friends or family member have an unlocked phone so you can see if the sim will connect on their phone.
@GordogSull you said you got this new sim card, so, you gone in My account and request change sim card there?
if you did, I would open a ticket with support to confirm if they did setup the new sim properly
1. Please open ticket via Chatbot (requires access to My Account) using direct link: https://publicmobile.ca/chatbot.
Start by typing "Contact agent ", then click "Contact Us", then click "Other", click "Click here to submit a ticket ↗""
Next, enter your Community login, then enter your question.  Finally use My Account login or 4 digits PIN to validate.
HALIMACS
@GordogSull
Is the phone "new to you"?
It's possible it may have been blacklisted.   Doubtful, but worth checking.
Check here:
Check the Status of Your Device in Canada | DeviceCheck.ca
GordogSull
I don’t have another phone.
GordogSull
I did replay Yes,it then took 5 calls to my previous provider to get the phone unlocked. Yesterday I call to verify and it was confirmed unlocked. Now no service shown top left.
@GordogSull
did you go to My Account and request Change sim card to tie this new sim card to your current account/number?
 And do you have another phone to test the sim card ?
HALIMACS
@GordogSull
Did you reply YES to the port authorization text from your previous provider, if you were porting your number from there to here?
If not, I can send you a number to call to complete the porting.   To get it, check your provide mailbox by clicking the envelope icon upper left.
hairbag1
@GordogSull
try your sim in a different phone...that iPhone 4S may be unusable here.
