11-01-2023 11:38 AM
Please tell me when will Public Mobile start providing phone services. The previous phone service provider has stoped providing services to me. Very inconvenience.
11-01-2023 12:57 PM - edited 11-01-2023 12:58 PM
You need a PM SIM or eSIM to get service so you need to PURCHASE one and activate the SIM on the PM app once you get the SIM in your hands.
eSIM only works if your phone is eSIM compatible. It won’t work if you have an older phone that is not eSIM compatible.
You can’t port your old number over to PM if your old account with the previous carrier is cancelled.
11-01-2023 12:40 PM - edited 11-01-2023 12:42 PM
@DaiSing Each cell service provider has a different sim card so when you change providers you need to get a new one. The quickest way for you would be to go to a Telus/Koodo store (phone ahead to see if they have Public Mobile sims) and buy one, unless your phone is capable of e-sim in which case you can order that online and it's available right away. If you have PM send you a physical sim card it could take 1-3 weeks.
11-01-2023 12:29 PM
I don't have Public Mobile Sim card. Send me one.I pay.
11-01-2023 12:17 PM
@DaiSing - we are all customers like you here on the forum, and have no access to your account. To rule out a device issue, try the public mobile SIM card into another phone to see if services work.
Does anything work on the public mobile SIM card, calling (in/out), texting (in/out), data? When services stop on the old provider's phone, that is usually a good indication the port is complete. OR, did you cancel the old provider's services yourself before the port was complete, because that could be an issue too.
If the port failed, then you will need to reactivate the old provider's account to re initiate the porting process with Public Mobile (unless the old provider was Koodo or Telus, there may be allowances here in this case).
11-01-2023 11:41 AM
Have you rebooted your phone since completing the port?
If that doesn’t work you can also try to reset your network settings and then reboot again.
If none of this fixes it, you’ll have to get customer service to assist you as it’s likely a SIM provisioning error on their end.
Please click this link below to message customer service:
Keep an eye on your mailbox here as that is where your reply will come in (envelope icon on desktop, click your avatar icon in the corner and then click messages if on mobile).
11-01-2023 11:39 AM
HI @DaiSing
so, the sim is not connecting to the network ? are you using physical or esim?
but it is just a setup problem and PM agent can check.
please submit a ticket with CS Agent here:
