No numbers available for selected city
Veranika
Hi. When I try to activate a sim card a choose a phone number for Toronto I get this error (see attached).
11 REPLIES 11
Veranika
So, I had waited for a couple of hours but nothing has changed since then. Followed the advice to pick any number and switch in Change number then. It worked. Thanks everyone! 😊
JL9
Did you try another city to get a number and just going to use change number or are you waiting to see if the numbers populate later today/this week?
I'm actually seeing both 437 and 647 numbers. The 647 area code is becoming more of a rarity and the 647 number and one of the ones that I saw is actually a really good one (repeating digits).
@softech  - I never used that Live Activation option myself. But, it is supposed to be 'live' humans helping. And, maybe they have an ability to see a phone number pool or certain extensions.
Who knows - 🤔
@esjliv   Honest, I don't think the live chat will be much help.  They never provide technical support.  The most technical thing they will do is to ask user to open ticket here
OP could benefit more to Live chat with you  🤣😂
dust2dust
I just did a trial activation and I got the same thing. Just find a number anywhere and then change it once you're all set up. Curious that activation draws from a different list apparently.
@Veranika
You have 2 choices
1. you might have to wait and try back again in couple hours.
2. Pick a temporary number now and then choose Change Number after it is all activated.   The screen I posted earlier is the Change Number screen from my own My Account.  As you see, you can Change a Toronto number after you became a customer
Veranika
Have just tried both options and neither worked 😞
dust2dust
Or just pick a number any number and then use that change number to find a Toronto number as above. It is curious that the activation screen doesn't come up with one in your case.
@Veranika   Try another browser or Incognito mode and it might work
I just tried and they did have Toronto phone numbers to pick
