a week ago - last edited a week ago by computergeek541
Went on vacation for a week and had airplane mode on. Came back today and haven't been able to get service back since I landed.
Can anyone give any recommendations?
a week ago
Sounds daft, but I had to reboot my phone for it to reconnect to PM after a holiday. Try rebooting.
a week ago
sorry, I meant remove Mon PM sim if any
So, you didn't use other sim while you were on the trip??
did you check if PM account is active?? only data has problem or voice as well??
a week ago
No I used the eSIM I have but phone was in airplane mode.
What Is mon pm sim?
a week ago
@Smann10 did you use local sim card there or travel eSIM?? Delete the travel eSIM, remove Mon PM sim
Check VPN screen and delete all the VPN profile there. Last, click Reset All Networks
Test the data again
