2 weeks ago
My phone can no longer connect to the Public Mobile network, voice or data.
I opened a ticket this morning, haven't heard back yet - am hoping they just need to reset my account on their end, or something like that. While I wait for them, thought I'd try here in case anyone can suggest something else I could try.
AFAIK nothing changed that would have caused this. I did change my plan recently, but I think that took effect about a week ago, and things were working fine until this past Saturday. At first I noticed my mobile data wasn't working, figured I might have hit a limit on my phone, then later noticed that calls weren't working either.
Here's what I've tried since...
I did notice one thing...
So, that's it, I think. If anyone else has anything else for me to check or try, please say & thanks in advance.
Tuesday
I've had the same thing happened. We switched a month ago and it's been nothing but phone calls being dropped, no network connection (twice in a week). PM asks to restart the phone, to remove the sim card and reinsert it, to check our surroundings. Sure it works for a few more days but then problems come back. This NEVER happened with our previous carrier FIDO. I though PM's network was more reliable being on Telus. I'm honestly getting frustrated having to send tickets all the time during my work hours. I have a Samsung A53 5G, anyone else having same issues constantly?
2 weeks ago
self solution removed/solution reassigned
2 weeks ago
Thanks for the help here - turned out my SIM did work on another phone, so I went ahead & got a new phone (mine was a Samsung Note 8 running Android 9, kind of ancient, but had been working fine til Saturday).
2 weeks ago
hi @JoeyJoeJoeShab if you have no voice as well, it had nothing to do with APN. APN only affects data
best to check your sim card as said above
or tou5cam also call 1-855-4PUBLIC and enter you number and it will confirm if any account problem
could also be local network problem
Last, ask agent to refresh your account. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
2 weeks ago
Ah, yeah, should've mentioned that my account is fully paid up & is in good standing - at least as far as I can tell from my account page.
2 weeks ago
Not yet, I don't have another one handy to try that with.
2 weeks ago - last edited 2 weeks ago
Have you tried your SIM card in a different phone? And as dumb as this sounds, have you confirmed your account is active? As in your credit card didn't expire or something, the last payment went through....
