12-22-2022 01:07 PM - last edited on 12-22-2022 05:31 PM by computergeek541
Hi there, I was just informed that holiday text and e-mails should have all been sent out by Dec 15 and for some reason I was never invited. Is this just for certain customers of something all customers should receive? How do I make sure I don't get missed next year? Thanks.
12-22-2022 05:32 PM
@JP23 wrote:Hi there, I was just informed that holiday text and e-mails should have all been sent out by Dec 15 and for some reason I was never invited. Is this just for certain customers of something all customers should receive? How do I make sure I don't get missed next year? Thanks.
The e-mail message was more of to inform customers to watch for the text message. It's the text message being sent that marked the customers as being eligible for the free add-ons.
12-22-2022 01:15 PM - edited 12-23-2022 06:00 PM
First, try to send YES2 to short code 4911
if you got back a reply saying they will add it, then you can check your My Account shortly after using Incognito Mode
if you got a reply saying you are not eligible, still no worry, just open ticket with PM Support using Chatbot and they will add it back for you:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
12-22-2022 01:12 PM
If you are new customer (signed after Dec 1) then you will get them automatically, no SMS/email needed.
Otherwise contact agent to update your account with these bonuses.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
