New phone same SIM card?
Pat18
Can I use the SIM card in my iPhone 7 in the latest version of the iPhone SE.
thanks
pat
@Pat18
Your account information is on your SIM so just pop it out of the old phone and put it into the new phone.
You might be thinking you're "closing" your question by selecting your post as the solution. May I recommend clicking on the little down arrow in the upper right corner of your post and undo the solution choice and then go to that other reply and select that as the solution.
Adding - lol already undone by an oracle.
JRod
Happy to help! Enjoy your new phone 🙂
Pat18
Wow!
thanks for the quick reply🙂
JRod
@Pat18
Yes you can! Just insert your sim into your new phone and you’re good to go!
Both iPhone 7 and SE use the same nano-sim.
