12-02-2023 11:25 AM
I ordered a new phone plan with a new SIM card. I have got the number, yet the phone doesn’t work.
12-02-2023 02:01 PM
Thank you. Physical SIM. I am an existing customer and want to add a number to a different phone. There is no ringtone or messages can be received.
12-02-2023 01:19 PM
Hi @Ela1,
Can you elaborate which step you are stuck on? Are you using the physical SIM or eSIM? Are you a new client or existing? What aspect of your phone doesn't work?
12-02-2023 11:30 AM
@Ela1 Are you using the app to activate it not the website . If same
you can send a private message To CS_Agents
