New SIM not working
pcuadros
I got a new sim in Wallmart and they did the activation but my got message NO SIM and cannot connect to the network. I have an iphone6. The phone is unlock and got following message with my imei:
Your device has not been reported as lost or stolen.
The Network Compatibility check cannot be performed at this time. Please try again later.
Check another device
7 REPLIES 7
pcuadros
You were right. My phone was locked by Bell but they couldn't find it becasue it was repaired so I had called a special department from Bell and they unlocked it. Works now
@pcuadros wrote:
why then it display Public Mobile as a carrier in my phone but with no network
@pcuadros  Try resetting your network settings to see if it makes a difference.
pcuadros
pcuadros
it was with Bell but they cannot find the imei
@pcuadros wrote:
I did and they cannot find my IMEI on their side. Could I call apple to unlock it? I had not used this phone for 2 years.
@pcuadros  Where did you buy yhe phone from? Wouldn't hurt to try Apple also
pcuadros
geopublic
@pcuadros  Your phone is locked. You need to call your previous provider and ask them to unlock it
