09-13-2023 06:58 PM
09-13-2023 07:48 PM
@BrantDumais- Do not answer that here. Reply to the agent here:
09-13-2023 07:47 PM - edited 09-13-2023 07:52 PM
Hello,
Thank you for your message.
I am happy to assist you.
I will write you a private message.
Regards,
Alan_T
CS_Agent
09-13-2023 07:27 PM
Are your services working? The email address is just a login id. Then the 2fa will send you a text.
09-13-2023 07:24 PM
yes i still have the account but im locked out of it due to my email being compromised so i cant log into my account
09-13-2023 07:14 PM
Please elaborate your request a little bit.
If you used to have PM number before, and you cancelled PM service, you cannot get that number as most likely it was already assigned to somebody else.
If you had service with other provider and you opened account with PM, you can transfer your 'old' number to PM BUT both accounts have to be active...
09-13-2023 07:06 PM
We definitely need more information here. Once you give more details, hopefully we can give you the best answer instead of sending you to a CS Agent first. It's best to get an understanding first of your situation. Thanks.
09-13-2023 07:00 PM
Do you mean you currently have a number here and want to bring in a number from elsewhere?
Or that you have lost track of an old number and want it back?
09-13-2023 06:59 PM
@BrantDumais You need to ask support to help in that case , use this direct link
send a private message To CS_Agents click
VVVVV Link below VVVVV
