04-19-2023 09:08 PM
I just bought a iPhone SE 2020 and the SIM card that I have in my old phone doesn't fit. If I get a new SIM card will it fit my iPhone SE?
04-20-2023 03:41 AM
Your iPhone will take the nano size SIM so carefully remove the spacer but be careful not to scratch the copper contacts. Place the SIM with the contact facing down on a flat surface and hold down the SIM and lift up the spacer with your finger nail. Sometimes time spacer will pop off.
04-19-2023 09:20 PM
@GR2010 most PM sim card , even old ones, are 3-in-1 sim card. There should be frames you can remove to make it smaller to fit your phone, check it:
Just in case you need a new one, yes, for sure it can fit
You can get a Public Mobile sim card from
