NOT REGISTERED TO NETWORK
MEC
I can't text or call.  When I tried to go to Network Operators (In Settings), and hit Select Automatically, it said "unable to Connect.  Try later."
I did this the second time and was able to connect to Telus.  Rebooted phone and tried calling family but it's still said I'm not registered.  So I did it again the third time by selecting Automatically in Network Operators but said the same thing:  "Unable to connect. Try again Later."  I tried manually connecting and got the same error.  I also tried removing and cleaning the sim card.  Been doing this all morning.  I'm away from family so my phone is my life line and my only connection to them.
Can anybody help, please??
Thank you so much.
hi @MEC it could be phone or sim card or network
do you have another phone around?? test the PM sim card with the other phone
if same,please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
MEC
Yes, I tried doing it manually as well but there's no "Public Mobile" in the options.  Only Telus, Rogers, Freedom, Bell.  I selected Telus (parent company of Public M) and I got the same "unable to connect.." error.
hi @MEC did you try to manually connect to Public Mobile?? can the phone sees the network when selezf manual?
MEC
I am in St. Catharines, Ontario (Niagara Region).
hairbag1
@MEC
could be a location issue as you haven't mentioned where you are yet. That might help if you told us where you am.
@MEC
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send  a  private message   To CS_Agents
