My autopay keeps getting declined, and I have funds in my bank acct
cjosephs
@cjosephs wrote:
Yes
Could you give more details on exactly what is happening?
“Yes” that your services are working?
“Yes” that your autopay is indeed failing?
cjosephs
Yes
HALIMACS
What do you mean it keeps getting declined? Is this happening every cycle?
If it is, I might recommend removing the payment card all together and maybe replacing it with another if that option is available to you.
If you're seeing this (below) and you have active service, you don't need to worry about anything, it's a normal renewal message ( which causes unnecessary stress to newer members):
TheGx
@cjosephs :Has this card worked before with autopay?
JK8
Are you going through a renewal right now? Is the status Plan Expired? As long as your phone works everything is fine. This is the normal renewal process.
