My account
TimDawson
How do I go to my account
TimDawson
Ty
@TimDawson
If you are a recent PM member, just login on your app or on the website.
If you are a longtime member, you will need to create an Eversafe ID before login so just click on Sign Up if you haven’t created an ID.
HI @TimDawson
usually the same email address used to login Community can login My Account  (So, the same email address used for you to loign @TimDawson  in your case)
you can access via here: https://myaccount.publicmobile.ca/
but if any error, post us screenshots
JRod
@TimDawson
Click the sandwich icon in the top right and then click Sign in.
This link will also take you there:
https://selfserve.publicmobile.ca/
Meow
Did you create one?
Just log in. If PM sends you a code to your phone but it does not arrive, change to receive it in email.
