09-20-2022 05:35 PM - last edited on 09-21-2022 12:43 AM by computergeek541
My account number I need please my phone number is xxxxxxxxxx and my name is xxxxxxxxxxxxx.
09-21-2022 07:36 AM - edited 09-21-2022 07:40 AM
No worry @Remember , we are here to provide the best and quickest workarounds to others without them having to waste time opening ticket with PM Support. So, you should be as happy and feel as great whenever users got helped, and most importantly, the correct help.
09-21-2022 02:00 AM - edited 09-21-2022 02:01 AM
I did not remove the solution. That was done by someone else. Posting the same thing over and over and consitently repeating orhers isn't helpful and will be considered as spam.
09-21-2022 01:08 AM
09-21-2022 01:05 AM - edited 09-21-2022 01:06 AM
what is your issue ? you keep remove my poster? also removeing solution why?
09-20-2022 11:15 PM
Yes. My Account, usage, 30 days, download. The download has it all......
09-20-2022 07:28 PM
@softech- It's even just a hover. You don't need to click on it. Clicking actually does nothing.
09-20-2022 07:24 PM - edited 10-21-2022 01:27 AM
Understand you picked a solution. Hope you are not still waiting for CS agent to reply
The account number is simply here after you login to My Account. Profile page, check the My Account Info section, click hover on the "eye" and it will show you the full acocunt number
And to remove your phone number, simply go back to your message, click Edit Message
09-20-2022 07:20 PM
@Yusuf113 - This is a public forum, please edit your post to remove any personal information. To edit it, hit the down arrow at top, right of your post.
In addition to finding your account by @hTideGnow method, if you received an activation email when you started with public mobile then you should see the account number in the TO line of that email.
09-20-2022 05:45 PM
Hi @Yusuf113
again, you can login to get the account number quickly. No need to open ticket with CS Agent and wait couple hours for an answer
09-20-2022 05:42 PM
09-20-2022 05:36 PM - edited 09-20-2022 05:37 PM
Hi @Yusuf113 login to My Account, go to Profile Page, the account number is there
Warm reminder, this is a forum, you do not want to post your number here. Pleased update your post and remove it
