My International Samsung S23 Ultra Not Working With Public Mobile
cam1982
Hi,
I bought the Samsung S23 Ultra while I was oversee (SM_918B) but when I put the public mobile sim card in. It does not work.
Any idea?
Thank you.
10 REPLIES 10
@cam1982
any change you can borrow a Freedom sim card?? usually Freedom sim card can do the trick to open up the APN menu so you can create new APN profile for PM
cam1982
Hi @softech
There isn't an option to add new APN.
ANd can't edit existing either. It grayed out
@cam1982
that can be an issue, I wonder if your APN is correct
Can you Add new (click on the + on top) and create a new one for PM?
cam1982
The option to edit APN is grey-out. Not allow to add or edit APN
@cam1982 Try Reset All network once
And check and update the APN accordingly:
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
cam1982
Yes, I am using physical SIM
cam1982
@softech
Voice partially work. Whenever I make call, it will tell waiting for complete long distant call even I call my other number in Ontario.
Data not working at all
HI @cam1982
are you using physical sim?
first, does the phone connect to PM network at all?  Voice working? just data not working?
Try to click Reset All networks and see if it works
Also, check VPN screen, make sure there is no VPN profile, disable or even delete them
cam1982
@Handy1  - I tested with Roger's SIM card, and it works fine. Because I had a great plan with Public Mobile, I don't want to switch to Rogers.
I heard the Telus whitelist the phone, so the other phone will not work. I think PM can help to whitelist my phone.
@cam1982  That could be a problem if it’s not a Canada model , can you test the SIM card in another phone to test ?
