My Account logon failing.
LurganIeUk
Just tried logging on to My  Account.
Failed then reset password to same password and worked
Tried wife’s, did not reset. Will try later.
I have correct passwords AND have entered without error.
Just a heads up.
9 REPLIES 9
@LurganIeUk, either one would be fine. But since, it's now 1230am PST, it's now the next day for you. It probably doesn't matter does it?
@mpcdesign wrote:
@LurganIeUk, you could also try in a private tab or incognito too? That would work too.
On Safari, on an iPad?
@mpcdesign wrote:
@LurganIeUk normally, when you reset the password, one shouldn't be using the same password for security reasons. If needed, I would just change a number or something.
Could you not fill the forgot password form?
Yes thanks. I did that for mine. Wife’s is locked out for an hour. Will wait till tomorrow. Hopefully the issue will clear.
mpcdesign
BearFBI
@gblackma you could be right. Whatever it is it's a glich that the moderators can fix
gblackma
@LurganIeUk  I wonder if your wife's failed because you tried it directly after yours?
Staliger
@LurganIeUk Contact moderators directly through the private message here  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Ask them for a temporary password.
BearFBI
PM's password reset is a bit buggy. I am glad to hear you reset yours no problem. You might have to contact a moderator to change your wife's  password.
You can use that link to contact a mod
