10-19-2023 09:59 PM
I got charged the same amount 6 times on my credit card bill for the exact same date.
10-19-2023 10:22 PM
did you just start a new PM account and had trouble with the activation process ? It mighta glitched out and charged you X 6 as a result of the glitch. Glitches can happen but only rarely here. Use the link provided by the others and I know the CSA will make things right.
Welcome to Public Mobile.
10-19-2023 10:12 PM
@boblegend21 that's unusual. Do you see all 6 transaction s showing on My Account 's transaction history?
dont worries, open ticket with agent here and they will investigate
but don't worries, support can help
10-19-2023 10:04 PM
When you login to your account, what does it show under your payment history?
You'll likely need to contact Public Mobile staff by sending a private message to @CS_Agent.
