Monthly purchased Data allowance missing
Marto
My new monthly subscription started yesterday. My 3 Gigabytes of data is said to be USED already. I was not using data on my mobile phone yesterday or today.
My usage history shows that I used 1.7Mb of data yesterday.
Can someone help me with this issue? It is urgent for me
15 REPLIES 15
Marto
I cannot accept that my phone could have consumed 3 GB of data instantly on the first day of my subscription. I monitor my data usage carefully. I had 1.5 GB of data remaining in my previous subscription. I know they do not carry over but it demonstrates how closely I monitor my data usage.
Marto
The usage history in my Public Mobile app shows that I only used a Megabyte or two on the day before and the day after my subscription began. Thanks for asking this.
this is why I can say that my three make a gigabytes of data have gone missing, unused by me. Someone else suggested that it could be used unknown to me. I suggest this would not be possible since I monitor my data usage carefully. Furthermore, at 3G download speeds, it would not be possible to consume this amount of data.
Marto
Thank you. The public mobile app on my phone shows the same information as the browsers. Public mobile even sent me a text to say that my data was used. Data usage history shows about 2.7 Mb used
@Marto have you tried using Private browser mode to login My Account and check the usage to avoid cache problem showing you the outdated usage?
if you did and still showing data are all used, check the usage history to see if it shows 3GB was used in the last 2 days:  https://myaccount.publicmobile.ca/en/account/plan/usage-details
if still I doubt with the data, open a ticket with support by messaging them:
@Marto  You most likely used it up unaware of it . Maybe a rougue app in background or OS update
Marto
I have done this. My public mobile app on my phone shows the same. I even received a text from Publicmobile saying my data was used up
Meow
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
Marto
Thank you. I will check this out for sure.
@Marto wrote:
No. This is not a data add on. This is the monthly  purchase of phone coverage plus 3 Gigabits of data. Thanks for your question
Sorry, my mistake.  By chance do you have WiFi assist on?  That will cause mobile data consumption even when on WiFi?  BTW, are you on a old 3GB plan that cost $30 or $35?  This plan offers 60GB over 90 days and costs $34 every 30 days based on a 90 day subscription.
https://subscribe.publicmobile.ca/en/on/activation/plans/20GB-4Gspeed
@Marto
Incognito mode is called Private Window on Mac
  1. Open Safari and click on File in the menu bar at the top.
  2. Choose New Private Window, and you will get a new window to browse privately in Safari on Mac.
  3. Alternatively, you can use the Mac shortcut Command + Shift + N to access incognito mode in Safari.
Marto
@Marto  you can use this link to ask support to investigate for you
send a  private message   To CS_Agents click
Marto
Hi, Thank you for the reply. Working on my Mac now and that suggestion did not seem to work. I don't know how to access incognito or private mode.
I see the name Maire is an Irish name, as am I. Just an observation. Thanks again.
Marto
will13am
@Marto , are you referring to data add-on?  Data add-ons now have an expiry, unlike the past.
@Marto  Probably just. Cache issue try the app or if on website
Try again incognito/private mode
And or lap top /computer
                    OR
simply try refreshing the page to check data plan / mins / add ons
