Moderateur svp
Paltrow
Moderateur svp
8 REPLIES 8
Hi @TheGx
I believe choosing an accepted solution is as easy as tapping on "Accept as Solution" button on bottom of the post the OP likes best.
That button is only visible to the person who initiated to thread.
dabr
@Dunkman  or @computergeek541  or other Oracles...please merge OP's threads.  Thanks.
TheGx
If the above reply posted helped you find a moderator, you should choose it as the accepted solution to your posted thread, do this by click the three dots in the top right corner of the above post and click accept as solution.
TheGx
@Paltrow :When you got ahold of a moderator, don't forget to choose one of the above posts you like best as the accepted solution for your original post, to do this go to their reply post you like best and click the three dots in the top right corner of their post and choose accept as solution.
Hi @Paltrow in addition to what @kb_mv suggested above, you may also send a private message to the Moderator_Team here.  You have to be logged in to your Community account for the link to work.
It may take up to 48 hrs (more or less) to receive a reply from the moderators.  Keep an eye on the envelope icon on top right for a number to pop up. That would be the moderator’s reply.
I hope this helps
RosieR
@Paltrow wrote:
moderator please
@Paltrow If you don't want to post what the issue is here contact a moderator. See below.They do not contact you.
How to Open a Ticket / Contact Moderators
1. Click Chat Bubble and type "Open Ticket"
2. Click "Contact PM Support"
3. Select "Account Specific Question"
4. Click "No, I Need A Human Now"
5. Select the link "Click Here To Submit A Ticket"
6. This opens a new window. Log in with Community Account NOT your self serve. Follow prompts.
dabr
@Paltrow wrote:
Moderateur svp
@Paltrow    If you need to contact moderators click the chatbot bubble bottom right of screen or send a private message to Moderator_Team here:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Perhaps you can explain your issue and someone here might be able to offer suggestions or advice before moderators reply as that can take several hours or day or two.
Paltrow
moderator please
