Mobile Network Not Available
wildstreak73
I have paid my bill up until May 7th, and I am cut off. I can't call, people can't call me, because it goes straight to a voicemail; which I also can't access. I never could becuase it says that it is not supported. @CS_Agent
1 ACCEPTED SOLUTION
Accepted Solutions
@wildstreak73  can you give some additional details.  voicemail access should imply the account is active.
did you recently port?  what phone are you using?  is your phone connected to the network?
when did you sign up? did the service ever work?
Is the voicemail of your old provider or Public mobiles?
Maybe try the lost stolen trick? click plans and addons -> lost stolen then toggle the mode for 5  minutes.
19 REPLIES 19
popping
Login to your self-serve account.
If your account status is NOT active, send a private message to moderator to fix the issue.
wildstreak73
It says "Active" but the network still is not available.  It has full bars atm.
hairbag1
Try Lost/Stolen remedy.
Log into My Account / Plan and Add ons / Lost-Stolen. Suspend service then log out for 5 minutes. Go back in and Resume service.
Good luck.
Try removing and reinserting your SIM and restarting your phone.
wildstreak73
The VM could be through the old owner's carrier, but IDK which one, as I bought the phone at a garage sale. I set it up through the set-up menu though.
If you know teh make and model of teh phone you can check compatability with willmyphonework.net
also do you have a friend who has an unlocked phone or is on teh telus koodo customer?  you can try using your sim in their phone that will help isolate account vs hardware issues.
wildstreak73
The phone works now, except the VM. It still says, "Sorry, we don't support the short code that you are trying to reach."
Did you not do a factory reset after you bought it?
