Migrate to new 50gb 39$ plan
Winger1919
Trying to migrate to new 39$ 50gb plan, but subscription just started new month ,no text notice, as usually got in past as an upcoming warning,,, app on android opens with wife's account all the time,  regardless, of whose saved username password is used, so thought was already setup fine,  and shows not to be
Phil_Adelphus
@Winger1919  "...no text notice, as usually got in past as an upcoming warning,,,"
PM stopped sending those upcoming renewal notices out earlier this year (around April I think?) so you can't count on that anymore, so best thing now is to set up a reminder in the phone or other calendar.
@Winger1919
because of the cache issue, it is best to remember to "log off" after you done with the app
or best is not use different devices to access the 2 accounts, or use browser for one and app for the other one to avoid confusion
@Winger1919  Yes the app and website definitely display differently . In app if you go to profile page you will see the name on account and phone number to verify
Winger1919
Thank you, I will reach out. For help,  since,  like I said,  I did select the new deal,  but app opened wife account,,,,  unless go into profile,  it is hard to know right away who account is actually open,  whereas thru the regular search window method of login, I get greeted with my name.
@Winger1919
for your app issue, try to logoff before you login again.  You can also click on the app and select clear data from the app settings, then relaunch the app
For your plan change issue, if the new cycle already started and you have not schedule a plan change earlier, you missed the time.  It is properly best to just go to your My Account's Change Subscription page and schedule the change for next cycle
But if today is only day 1 of your new cycle, there is a slight chance support can help.  Please message them and check
@Winger1919  .yes this is a glitch and sometimes happens when making  scheduled plan change for next renewal just have to submit ticket with support
send  a  private message   To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
