02-08-2024 10:12 AM
When making calls in U.S>. do I select
1. Home country
2. Roaming Country
3. No Country Code
Thanks
Ben
02-08-2024 10:31 AM - edited 02-08-2024 10:31 AM
@ben_miskin I don’t think you need to worry about any of the options you listed in your thread . If you can make calls text and use data great . pM is pre paid and you will never get a surprise bill you can only use what you have already paid for . So if it’s all working no need to do anything
02-08-2024 10:27 AM
That is not the issue can make calls but do not know what option from the ones listed I should be using.
02-08-2024 10:22 AM
@ben_miskin When in the U.S. ensure you have data roaming turned on in phone settings . And set phone to 4G/LTE not 5G and connect to T mobile or AT&T . If you have any issues with voice try phone set to 2G and connect only to T mobile
