MMS can't open
radolichev
I can't open the MMS. It sais Download failed
14 REPLIES 14
aharisi
I've been having the same issue with MMS timing out for the last week or so. Have the APN settings changed from those published here https://www.publicmobile.ca/en/qc/get-help/articles/set-up-data-on-an-android-phone ?
@softech- 1 is still Android 8. The other two are 12. It just jumped out at me as appearing non-standard so I asked.
@dust2dust   Android 12?
But if not everyone has it.. that's not an important parameter anyway.
@softech- Odd. 3 Samsungs in the house and neither of them have that.
radolichev
Reset the settings of APN to default. The phone is Samsung Galaxy J7 Prime.
I receive MMS, but  it stopped 3 days ago without any reason
Thanks again, guys!
[default settings, eh! ........... Luddite]
@dust2dust wrote:
@softech- What phone has MMS Protocol? I don't recall seeing that before.
@dust2dust   Samsung has that..
Great news. How?
radolichev
It's now repaired! Thanks a lot!!!
@radolichev   were you ever able to download MMS message before?  If you never able to , check your APN settings
You can compare with this, or post us a screenshot of yours
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MMS Protocol: WAP 2.0
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,mms,agps,supl,fota,hipri
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
Bearer: Unspecified
MVNO type:GID
MVNO value: 4D4F
Timer
@radolichev
what device brand and model.
radolichev
Data is always on
Meow
In order to send/receive MMS you have to have DATA On. Your data allowance will not be used but that setting has to be ON.
dust2dust
Did you turn on the mobile/cellular data?
