Loyalty reward
Leanslow
If you change plan with a other public mobile plan, is the loyalty reward set to zero?
alexisdupre
No, loyalty rewards won't reset if you change plan.
self solution removed/solution assignment corrected
Leanslow
Thank you
Hollister
@Leanslow
Changing plans do not change your rewards/points. If you do change plans make sure to choose change on next renewal date otherwise for an immediate plan change you will receive no credit for your current plan.
dust2dust
No.
