06-23-2021 06:07 PM - edited 01-06-2022 02:36 AM
I lost my sim card but just purchased a new one. How can I swap it? Urgent help will be appreciated
06-23-2021 10:37 PM
@computergeek541 wrote:
@BKNS27 wrote:You should log into your self serve account and click on View My Usage>Lost/Stolen Phone to cancel the old SIM.
Then tap Change SIM Card>follow the prompt.
In addition to @Anonymous information about how lost/stolen does not cancel a SIM card, self serve can no longer be used to change to a new SIM card. As mentioned earlier, a moderator's help is needed.
@computergeek541 : I was willing to accept that "follow the prompt" meant to follow the instructions there...to ask a moderator.
But that's just my interpretation. 🙂
06-23-2021 09:54 PM
06-23-2021 08:18 PM - edited 06-23-2021 08:19 PM
@BKNS27 : The Lost/stolen function doesn't "cancel the old SIM". It suspends the service. You can Resume the service afterwards with the same SIM. In this case, the OP would want to Resume the service on the new SIM if they suspended it as you rightly suggest.
06-23-2021 08:13 PM
06-23-2021 06:29 PM
your welcome to public mobile
with a Beautiful Service
you will be very happy
Good Luck
06-23-2021 06:25 PM
Thanks so much for this
06-23-2021 06:12 PM
Only one way to solve your issue , explanation to customer service by Moderator Team
and the are nice service Team the will help you 100%.
you have to Submit a ticket to customer service by Moderator Team,
Here’s how to contact customer service by Moderator Team,
Good Luck
