Lost my phone number by mistake
Taleshi
I changed my phone number by mistake, I am very disappointed,
Is there anyway to get my phone number back?
8 REPLIES 8
pkaraa
you might get your old number back If you can get some CSA to help you then within 90 days of you giving up your old number.
0PX9O4
@Taleshi
You may want to contact @CS_Agent urgently by private message. If your old phone number has not been activated on another account, you just may be able to get access to it again.
CountyDownIeUk
Is there anyway to get my (OLD) phone number back?
@Taleshi
Huh 🤷🏼 🤦 how did you do that?
Once you give up your number. It is put on hold for 90 days before resigning it.
It is slim but contact a PM CS Agent and they might be able to help.
@Taleshi   did you request to change your number yourself?
answer to your question .. very likely you won't be getting it back
for you old number , did you get it new from PM?  or you port it into PM?  If you ported it in, when you gave up your number, it will go back to the original provider you got it from before and hence PM won't be able to help (the number already gone back)
If it was a number from PM, there is a slight chance, very slight chance,  if PM willing to help.  You can try to open a ticket and check your luck
 @Taleshi : How do you go through all those steps and then click go (or whatever) and go whoops. Why wouldn't you back out before that?
@Taleshi  - how did that happen? Sorry to hear this.
Were you suspended for over 90 days, this would do it.
Do you know if the number is still available? Have you called it?
You can't really get a number back, officially.
What are your particular circumstances here?
https://www.publicmobile.ca/en/on/get-help/articles/contact-a-moderator
@Taleshi
you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
they can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Support Agent by CS_Agent,Click Here link,to get started. Type,, Ticket ,, Click ,, Contact Us ,, Select your issue ,,
    Click here to submit a ticket↗↗.
  • or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
  • phone number,
  • account number,
  • account 4 digit pin,
  • Email address,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
  • During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
    • Monday to Sunday: 6 AM to 10 PM EST
         Good Luck....
