Loosing connection and can't open a ticket for support
Carolin
I'm loosing connection intermittent. It comes back when I reset the internet or restart, at least most of the time. But most of the times when I leave home so switch from wifi to mobile it doesn't work and it doesn't connect to internet. Really frustrating
I am also unable to open a ticket. Getting an error everytime no matter if I try through the app or website.
11 REPLIES 11
Carolin
Thanks I will try that. Never came to mind 😅
RavingRaven
@Carolin
Try toggling airplane mode on/off. If you have a poor connection to the network this will give you a brand new connection. You may have a small dead zone in your vicinity that affects your connection when you pass nearby or through it. If this fixes it just remember toggle airplane mode on/off again next time. You may even be able to narrow down where the dead zone is and avoid it altogether.
@softech wrote:
thanks @will13am , I  believe based on my successful experience 🙂
You've wiped a SIM and brought it back to life?  Good for you.  Not something I would ever do.  A dirty SIM means an even dirtier SIM slot.  Have any solutions for that?
@softech wrote:
@will13am
not bad for p-sim.  while is not common, a lost contact on some phone is possible.  Not a myth but proven success.  🙂
But I usually suggest putting it to another phone as this will do both reseating as well as a force reprovision when the sim is used on another phone
Really?  I have not seen once anyone in the community say that scrubbing their SIM clean made any difference.  My SIM is an original from 2016 and it has been tossed into more phones can I count.  It is pretty worn but still works.  I would never wipe the contacts and add to the physical wear.  I guess you can believe whatever you want.
@will13am
@softech wrote:
@Carolin
try to reseat the sim card.  Power off, take sim out and wipe clean, put it back and power up
or better to try your sim card in another phone so you can confirm it is not a device issue
if you need, open ticket with PM support and ask them to reprovision your account/sim:
Bad suggestion even if for a p-SIM.  There is no chance of contaminants getting into a SIM slot.  Rubbing the SIM contacts can only lead to wear and tear and likely reduce its reliable operation.  I don't understand the popularity of this myth.  🙄
Carolin
Have a pixel 7 pro. Doubt it's the phone, worked before with other carrier. I have an option to reset the mobile connection which works but not always will try the 4g option thanks 😊
@Carolin
you can only reboot the phone then  🙂
what kind of phone you have?
and try changing network mode from Automatic to 4G and test if it works better.
Carolin
Thanks. Only have e sim so won't be able to try the suggestion 😅will do pm
@Carolin
