Locked phone
embacher
How do I check if my phone is locked.
2 REPLIES 2
Triguy
Check your phone settings.
go to Settings --> Cellular look for  Cellular Data Network if you can find this option, then your Phone is unlocked, but if not, your Phone is locked.
geopublic
Insert a different sim card from another provider if it asks you for a network unlock code then it's locked.
