Locked out of account, need account number
Hamed1962
Hello,
I attempted a password reset but forgot my security question. I keep getting myself locked out when trying the passwords I remember. My credit card on file expired and my plan is on hold, thus I have no service at all.
Please help me log into my account!!
8 REPLIES 8
Hamed1962
I tried to make a payment on 611 but you have to use a card that is already on the account and mine has expired so I needed to add a new credit card.
How do I contact the moderator team?
@mimmo wrote:
@will13am  i believe you dont need a pin to apply a voucher, only to make paymeets with creditcard, possibly to buy addons.
Okay, I stand corrected then.  Makes it even easier to go this route.
mimmo
will13am
@Hamed1962, as already suggested, the only recourse is to seek moderator team assistance to complete the password reset.  Since interaction times are very long, you might want to consider getting a voucher and applying it via 611 to restore your service assuming you still know your account PIN code.
ChuckYeah
If you can't get into your account or use 611,
Contact @Moderator_Team
It can take up to 48 hours for the team to respond to your concerns.
About @Moderator_Team
They are the only ones that'll be able to help you.
harrypham1205
Try to guess the security question a few more times, and if that doesn't work, contact a moderator immediately, hope it gets resolved. 🙂
Triguy
You could buy a voucher and call 611 to make a payment in the meantime.  Did you try using a different browser and incognito mode.  Also try to clear your cache and cookies then reboot and try logging into your account.
