Legacy rewards vs points, which is better?
MMK5
Should we switch to points or stick with legacy rewards? I find legacy rewards is more profitable, let me know your thoughts.
MMK5
Thanks, for the confirmation and explanation.
MMK5
Yes, I thought the same, legacy rewards is best but want to make sure I'm not missing any fineprint. Thanks.
HALIMACS
Another thing to consider @MMK5 , is Public Mobile makes it non-reversible.
Once a user switches to Public Points, there's no ever going back to the legacy rewards.   The reason they do this is obvious.
They SAVE more offering Public Points than from the Legacy rewards.
Don't get me wrong, rewards are rewards, and we all should be happy to get them.
It's just the legacy reward holders are happier - and we love it that way.
Chalupa_Batman
Hey @MMK5
Rule of Fight Club....   NEVER switch from using Legacy Rewards. Nobody here in these forums will EVER tell you to switch.
HALIMACS
Without a doubt, the legacy rewards are better.
Please don't, EVER, switch.
The loyalty rewards alone max out at $10/year on public points.
On the legacy rewards, you get $12/year after year 1, $24 after year 2, going all the way up to $60/year after year 5.
