Legacy plan data coverage
Rush2
Hello,
I have a legacy 90 day plan, i will be travelling to Quebec for couple of days and was wondering if my data will work without any addon or roaming charge?
DDM69
Huh?? 🤔
@Alexandf wrote:
@Rush2
this company not have any extra charge. if you plan not cover what you have it's not working.
if you needed to by works there buy it add-ons for 500min for $5 canada w talk.
The customer isn't asking about long distance calling.  Long distance add-ons don't help with data usage.
@Rush2 wrote:
Hello,
I noticed that you're asking about past 90-day plans.  None of Public Mobile's plans (post Telus purchase) have ever had any difference in network coverage/data coverage when compared to any of the other plans.
@Rush2   yes, your data will work without problem.  Data is Canada-wide, so you can use it anywhere in Canada without extra fee.
Enjoy and have a safe trip
RossN
@Rush2 hi you will have no issues using your data while you travel anywhere in Canada
Alexandf
@Rush2
