07-06-2017 04:44 PM - edited 01-04-2022 02:17 PM
Hello,
This is my first post on the PM forum.
I'm considering buying an LG G6 H870DS from Hong Kong and was wondering if it will work on the PM LTE network. I found a good deal on the phone but if it does not work I'll have to settle for a North American LG G6. Appreciate the help!
Thanks.
08-09-2017 10:37 PM - edited 08-10-2017 11:54 AM
08-09-2017 09:45 PM
This is the issue I am facing as well. My cellphone is dying so I need to get a new one...Ka-ching$$!!
I'd prefer to buy used to keep the cost down but I just don't know about compatibility with the Public Mobile Network. I'm looking at the LG G6 or a Google phone. What if the phone is unlocked but from the US?
Has anyone heard of BLU cellphones? Does anyone know if they work on the PM network? They are unlocked & cheap!
07-06-2017 07:00 PM
Thank you for taking the time to look into this for me. Much appreciated all!
07-06-2017 06:40 PM
07-06-2017 06:24 PM
07-06-2017 06:18 PM
07-06-2017 06:13 PM - edited 07-06-2017 06:19 PM
@zhadj030
Good job finding those specs! It will work fine. B12 is always deployed simultaneously with B17, and this phone supports B12.
The only main band missing is B2, which doesn't impact coverage. B13 and B29 are also missing, but B13 is never deployed on its own, and B29 is only for CA.
@sylh3t, I say go for it, you'll have no issues.
07-06-2017 06:07 PM
Here are the PM/Telus bands: https://en.wikipedia.org/wiki/Telus_Mobility. Compare that to the specs for your phone.
07-06-2017 05:43 PM
Yes I've tried this website and the LG G6 is not listed =(.
07-06-2017 05:30 PM
07-06-2017 05:23 PM - edited 07-06-2017 06:22 PM
07-06-2017 05:22 PM
