02-24-2022 01:58 PM - last edited on 06-02-2022 12:00 AM by computergeek541
Hi
I'm new to Public Mobile, i signed up to pay $35.00 CA for 30 days. I pay that, which i don't understand why you took $40.25 and $79.10 CA?
02-25-2022 12:49 PM
@conquistadorkab wrote:I living in Saint-John N-B Canada, it is my first time using Koodo.
@conquistadorkab You meant first time using Koodo or Public Mobile?
If you never use Koodo before and first time to use Public Mobile , I think you should open ticket with PM Support and have them to investigate. The charge amount does not make much sense to us. $79.10 is $68.78+tax in NB, PM usually does not have a charge like that..
If you have not open a ticket with PM Support yet, please do so
02-25-2022 12:31 PM
02-24-2022 03:04 PM
I believe charges for Koodo services would display as KOODO MOBILE PAC, unless the OP was with Koodo as a pre-paid customer.
Were you possibly with Koodo pre-paid previously, @conquistadorkab ?
02-24-2022 02:15 PM
@conquistadorkab I believe you are in Quebec. $40.25 is the correct charge. $79.10 would be $68.80+tax. Any chance you were with Koodo before you join PM? I don't think the $79.10 is related with your PM account
02-24-2022 02:03 PM
@conquistadorkab : The $40.25 is fine at 15%. But that $79.10 makes no sense.
02-24-2022 02:00 PM - edited 02-24-2022 02:01 PM
That IS unusual if you only have ONE public mobile account on the $35 plan @conquistadorkab
I would contact the CSA's to get the other one credited back.
