01-05-2022 08:54 PM
Hi,
I checked on here and it didn't have this model on the list. I'm in the market for a new phone and it seems like it's reasonably priced.
01-05-2022 09:02 PM
Yes is will working with Public Mobile.
visit Here link to you review full information,
Public Mobile uses the following frequency bands:
visit Here link, to check it all Provider in Canada about compatibility with any device..
01-05-2022 09:01 PM
@tallguy wrote:Hi,
@tallguy - the compatibility checker is not up to date in the help articles.
I suggest you check compatibilities prior to purchasing for Public Mobile.
Always good to check whether a phone will work with any provider, especially Public Mobile. Use more than one source to be sure.
https://www.kimovil.com/en/frequency-checker/CA
This looks like yours, check the links above to confirm.
3G or WCDMA 2 (1900 MHz ) and 5 (850 MHz) bands makes the phone compatible, which is needed for phone calls, and can also be used for text messaging and data.
LTE can be used for text messaging and data.
01-05-2022 08:57 PM
Yes it absolutely is.
01-05-2022 08:57 PM - edited 01-05-2022 09:05 PM
