Is the Motorola Moto E6 phone compatible with Public Mobile?
rosedale
I want to buy the Moto E6 and switch the sim cards from my RCA phone that I have on the Public Mobile network.
15 REPLIES 15
@rosedale
If the APN supplied by @softech does not work slight adjustments can be made. Report back if you are still having trouble.
@rosedale   was your Moto E6 you got brand new or refurbished .?  just wondering why the battery life that bad.
With the APN, did you try to reboot it multiple times?  sometimes it will come down automatically.  If not, you able to manually update it from blank to the proper values?
Go to Settings->More->Mobile networks->Access Points Names
Press + on the top right
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Leave blank
APN type: Leave blank
rosedale
Thanks everyone for the comments to my question, so I bought the phone and it does work om PM, however the battery life was only about 9 hours with very little use, I tried all the tricks to improve it but nothing worked so I returned the phone.
Now purchased an ASUS Zenfone Max Plus, amazing battery life but not able to use my data, my APN page is blank, I think that is the issue, just have to figure out how to populate.
@rosedale
Are you a costco member or know someone who is a member? Costco is clearing out their moto phones including the moto g fast and moto g play and others for $99.99. Check your local costco for stock.
You might be able to get a lot more phone for a lot less money.
@Anonymous wrote:
@hairbag1
please visit HERE and see full info.
3G bandsHSDPA 850 / 900 / 1700(AWS) / 1900 / 2100
 CDMA2000 1xEV-DO
4G bands1, 2, 3, 4, 5, 7, 8, 12, 13, 14, 17, 25, 26, 30, 66, 71
SpeedHSPA 42.2/5.76 Mbps, LTE
@rosedale
my dear is will working 100% with public mobile network.
  if you like that device to buy it, visiti HERE for $149.99 ,
You initially recommended willmyphone work to OP...but I can't find Moto E6 there.
@hairbag1
 CDMA2000 1xEV-DO
@rosedale
@rosedale  yes, there are just too many phones out there and hard for PM to add all of them.
Moto E6 is actually available in Canada (not those imported phone), so, no problem to be used on different networks
rosedale
Right but the exact model was not listed on the PM compatibility pull down,
But looks like it will work per some of the comments since I asked.
I will pick it up and post my feedback.
rosedale
$179
rosedale
Found one at Staples
@Anonymous wrote:
Yes will working 100%
for public mobile phone compatibility
you have to put it a device brand for any phone to you can see all information,
visit Here  to you can full information about your device.
you can visit HERE
following  >> To find out if your cellular phone is compatible with our network, click  HERE
Good Luck
You recommended looking at willmyphonework but I can't find it mentioned anywheres. Did you find it somewhere before you recommended it ?
@rosedale   Yes, E6 and its couple sub-models should work on PM without issue.
Where you getting the E6 from?
you can visit HERE
Good Luck
Yummy
It should be since my E4 works just fine with PM.
Dunkman
@rosedale
This phone is compatible with PM
Here are the specs:
https://www.gsmarena.com/motorola_moto_e6-9682.php
 CDMA2000 1xEV-DO - Verizon
4G bands2, 4, 5, 12, 13, 25, 26, 41, 66, 71
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
