12-07-2023 05:28 PM
Tried all the trouble shooting tips I can find.
12-07-2023 11:48 PM - edited 12-07-2023 11:49 PM
@BKNS27 wrote:My sister is using an iPhone 6 with PM SIM…no issues.
Sounds like a porting issue. Did you reply with YES to confirm you are porting over with the old SIM in your phone?
It is the most important step in the porting.
The new Public Mobile SIM card not wokring in the phone/not connecting to the network isn't a porting issue. Even with a failed port, there would still be a network connection. Data would work, and ougoing text messages and outgoing phone calls would also work. Someing incoming text messages and some incoiming phone calls would also work as long as they originale from within Telus.
12-07-2023 08:57 PM - edited 12-07-2023 08:58 PM
12-07-2023 06:52 PM
Okay my bad network is running but what i said about the card swap is a must for porting over. Hope this helps
12-07-2023 06:49 PM
@lunalightning1 " have to ask is anyone else having an issue with not connecting to the network right now?"
Working fine in my part of Ontario. Last few times I've looked at the Telus outages map there have been outages in BC and Alberta. You might want to check that.
12-07-2023 06:36 PM
tried in the last minute and appears the network is down. In seeing you are a new customer adding a new sim its really important to follow the swap over from your previous provider exactly as instructed keeping your previous providers sim and connection going until precisely the right moment as to swap. Then only do you insert the public mobile sim and for me had to reset network setting to get it to work . I am using my phone in the south surrey area and have no network connection at the moment. I would also have to ask is anyone else having an issue with not connecting to the network right now? If thats the case you must wait for the network to be up and running. I believe it down now
12-07-2023 06:36 PM
@Catherine1962 "r the number not yet ported over?" Did you get a text message on your old provider's sim asking you to authorize the port, and you replied YES before putting the PM sim in the phone?
12-07-2023 06:25 PM
New SIM not working in either phone.
12-07-2023 06:22 PM
Hello,
Thanks for the input.
Same phone different Public Mobile SIM and it works.
Problem with the SIM or the number not yet ported over?
12-07-2023 06:11 PM
This may be a stupid question, @Catherine1962 , however i gather the device has worked before, with another provider?
Can you try another SIM card (from a friend/relative/neighbor) to ensure the device can (in fact) connect to a mobile network?
While you're at it, try your recently activated Public Mobile SIM card in another device to see if it can connect to the network.
12-07-2023 06:11 PM
i think the network is down right now. I have also been trying to connect on my samsung s29 fe and it is showing no internet connection and all of my settings are correct . It has not been an issue for me in the past but is at the moment so i would suggest giving it a bit of time. If you are just connecting for the first time i would suggest to reset network settings on your phone but like i say id wait a bit because your post i see 35 mins ago and im having the same problem,
12-07-2023 05:40 PM
@Catherine1962 You can contact customer service at this link if the suggestions by @HALIMACS don't help.
They'll reply to your community inbox at the envelope icon top right, or at Messages in a drop down from your avatar.
12-07-2023 05:38 PM
New customer, physical sim
12-07-2023 05:37 PM
If you are within the service area, try rebooting your device and resetting network connections.
12-07-2023 05:35 PM
@Catherine1962 Are you a new customer, or are you an existing customer and this is a new problem? Are you using a physical sim or an esim?
