01-09-2023 08:23 PM
I cannot access the internet with my iPhone SE. I have internet thru my home network so I know it is not my phone, but I cannot access the internet away from home. I live in Calgary, so I think it should be easy to get a connection in this city. My "Network Selection" is Public Mobile. What am I doing wrong?
01-11-2023 09:06 PM
Bear with us Android users....we often have to rack or brains to remember how Apple devices work. There is a new iOS version available. Connect to wifi or iTunes and and go into your settings to update your software. Follow the prompts and you should be given the option to update your carrier profile. But as reiterated by @dust2dust refresh your usage page to ensure that you have data still available to you in your account.
01-11-2023 08:55 PM
In relation to data available, did you click on the little spinner refresh icons lower down to make sure you're seeing current information. The 250mb could be a solid red bar. But then you might also have data add-ons. Particularly the recent 2gb from December.
Your home network IS wifi. It would almost certainly have a password. If not then all your neighbours would be enjoying free wifi.
And of course the easy, obvious, did you turn on cellular data?
01-11-2023 08:46 PM
Reply to the many who tried to help me – thank you so much. I am not particularly computer/cellphone literate so I struggle a little with some things. Nevertheless, I provide a synopsis your suggestions and my responses to all those who provided their suggestions:
Your suggestions:
1. Handy1 - reset network settings / is network setting on 4G/LTE
2. popping (Oracle) - if your PM plan has date (sic, data), you need to make sure that to enable the mobile data before you can use the mobile data on your phone when you are away from your home WiFi signal. (Same advice given to me by Halimacs, dust2dust and hairbag1)
3. Halimacs - Make sure to clear cache and cookies and open an incognito tab before logging in there. If you still have data remaining, try resetting your APN settings.
4. darlicious - What iOS version are you running? Check for software updates and update your carrier profile. When was the last time you were able to use mobile data?
5. County DownleUk - are you saying that you cannot access wifi? Assuming you have the wifi network password.
My attempts to implement your suggestions:
1. Network setting is either 3G or LTE. I have it on LTE
2. Lots of data available – 77.25 of 250 MB used.
3. I cleared the data and history through Safari. I am not sure how to reset the APN, however, as I only seem to have an APN setting for my personal hotspot. My network selection is Public Mobile and that appears to be automatic.
4. The iOS version I am running is 15.7.2 and I don’t know how to answer your question about when I was able to use mobile data, other than through my personal hotspot. I very seldom, if ever, use something like Google on my cellphone. In fact, I seldom use any of the data on my plan.
5. If there is a WiFi network password, I don’t know what it is and I don’t know where I would input such a number.
01-10-2023 01:25 AM
01-10-2023 12:52 AM
1. When you have a wifi connection and you have data switched on.......your phone should only be using wifi.
2. When away from home internet/wifi with data turned off....are you saying that you cannot access wifi? Assuming you have the wifi network password.
01-10-2023 12:21 AM
We are not doing a good job to educate new subscribers.
We were guessing the problem with OP for the last 6 hours and provide the solution. It s/he stays on the community to provide additional info. OP's problem will be solved by now.
[Rant]
Over 4 years ago, I have the same conversion with Z10... that why people are not checking for answer after posing the question.
[/Rant]
01-09-2023 09:43 PM
One of the reasons pm eliminated retail activations was due to the fact that the salespeople were not properly trained or educated about the services public mobile offers. But I suppose the salesperson did avail you to faster data speeds depending on network traffic the 3G network will average 10 to 12mbps up to 20+mbps.
01-09-2023 09:17 PM
check to make sure you haven't consumed all your allotment of data....
If you see no mention of any data..that means it's used up until regular plan renewal or you buy a data add-on.
01-09-2023 09:09 PM
@darlicious @When I first discovered pm it was a 3G plan I picked and the guy at the store said to set my phone to 3G even thou my phone was on 4G at the time … so naturally I figured that could have some sorta impact on op situation and trying to help trouble shoot . But thank you for the clarification now I know
01-09-2023 09:02 PM
It doesn't matter whether or not you have a "3G" or "4G" plan you can use either the 4G LTE or the 3G network for data. The only difference is whether your 4G LTE data is throttled to 3mbps or not.
01-09-2023 08:59 PM
01-09-2023 08:35 PM
Do you have data left in your plan or add-ons? Did you turn on cellular data? Has it ever worked on this phone since you signed up with Public?
01-09-2023 08:34 PM - edited 01-09-2023 08:36 PM
Check on self-serve to see if you have exhausted your data allotment. Make sure to clear cache and cookies and open an incognito tab before logging in there.
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-iphone
If your PM plan has date, you need to make sure that to enable the mobile data before you can use the mobile data on your phone when you are away from your home WiFi signal.
BTW, I am in Calgary and I can use my PM mobile data after switching off my WiFi.
01-09-2023 08:29 PM
Outage map in your area:
https://istheservicedowncanada.com/status/telus/map
did you try to reset network settings / is network setting on 4G/LTE if that’s what your plan is or unless you have 3G plan is it set to 3G
