10-29-2021 07:28 PM - edited 01-06-2022 03:54 AM
Hi, I have unused international minutes on an add on on my account but when I try to make an international call it says that I have used all minutes, any suggestions?
thanks
10-29-2021 07:53 PM - edited 10-29-2021 07:54 PM
@Jordan6 If you purchase the UK mins add-on, make sure to omit the zero in front of the UK city area code, otherwise your call won't complete.
Edit: lol...nvd, just read @Anonymous mention that.
10-29-2021 07:41 PM
@Jordan6 wrote:Oh no, I'm calling the UK, i bought these minutes to call New Zealand but didn't check if the UK was on there. How do I add minutes to call the uk?
Thank you!
@Jordan6 You need to purchase the $15/1000 min UK add-on now. The old add-on included UK as part of the original international mins list, but the newer add-ons don't have that option, unfortunately.
10-29-2021 07:41 PM
@Jordan6 : If you have the old 400 minutes or the gifted 400 minutes or the gifted 500 minutes then some of the countries could be different.
If you're calling outside of Canada/US then you need to add a + or use 011 to "get out of the country". Then proceed with the country code and area code and the rest. If there's a leading zero somewhere then drop it.
10-29-2021 07:40 PM
@Jordan6...get the 1000 UK minutes add-on for $15
10-29-2021 07:39 PM - edited 10-29-2021 07:39 PM
@dabr wrote:Try adding +1 in front of the number you are calling and make sure you have the right code for the country you are making the call to.
+1 should only be added if calling countries in North America that use that code as +1 is the country code. If +1 is mistakenly added in front of phone numbers to other countries, the call will not complete.
10-29-2021 07:38 PM
Thank you!
10-29-2021 07:32 PM - edited 10-29-2021 07:43 PM
@Jordan6 wrote:Hi, I have unused international minutes on an add on on my account but when I try to make an international call it says that I have used all minutes, any suggestions?
thanks
@Jordan6 Are you calling one of the countries on the list for your international minutes? Also you've confirmed you still have minutes available from that add-on?
Edit: Are you calling one of these countries for the international minutes:
