Incorrect ESN/MEID for number port
paopao123
Hello,
I got a message saying I entered an incorrect ESN/MEID when porting my number. Is there someone I could contact to fix this? I think there's a Telus contact I could reach out to, could someone send that to me? Thanks!
@paopao123
glad it works!!
We saw it worked with IMEI, but to be honest, there is bigger chance or error using IMEI instead of account #
paopao123
It is resolved now by calling the Support Number. I had to use my account number. I really don't think they should let you use IMEID as a option for porting number if it doesn't work. Thanks for the help everyone.
@Priority wrote:
Also, you can resubmit the Port Request if you are able to access your Account.
Unfortuantely, this won't work.  After a port has been submitted, a customer going into Self Serve and trying to port again will always encounter an error message. In this type of situaiton, support msut get involved.
Priority
Are you able to sign in?
Priority
Don't use IMEI for port in, I've never had success doing it that way. Always use Previous Provider Account Number.
@paopao123
no worry, there is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  But the team is currently closed , so call them tomorrow morning and get it fixed
