08-18-2022 09:50 PM
Hi.
Both husband and I have been with Public since 2018. Had no issues. We moved into a new place in toronto last year with no issues until two months ago both our phones (google pixel3A) have very often not be able to get incoming calls. The calls go straight to voicemail and we get the voicemail notification but no missed call notification. It will also often not allow us to make outgoing calls and will say "cannot connect to network". After that happens the signal bar will show no signal then within a second will be back at full bar and we can make outgoing calls again.
Please help!
08-18-2022 11:52 PM
First, the voice calls are ok when you are away from your home?
it's a good test to change the preferred network to 3G Only (as many suggested above). But likely after changing to 3G Only, both your phones will not be connecting to the network, or you will see the connection on and off a lot. If that is the case, i suggest you open ticket with PM support and see if they are aware anything wrong with the 3G network around your place
To open ticket with PM support:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
08-18-2022 11:44 PM - edited 08-18-2022 11:45 PM
This will help in determining how close a Telus and Bell tower are in your new location:
Telus and Bell share signals on their towers.
In my area, there are more Telus towers but not so much of the Bell or Shaw towers.
Keep in mind that a tower is nearby but there could be dead zone blocked by high rises or if you are in a valley.
08-18-2022 09:56 PM
@Ooch123 hi manually change your network settings to 3g see if that helps
08-18-2022 09:56 PM - edited 08-18-2022 10:25 PM
manually select network 3G only, and rebooting device...Edit: How Switch To 3G
08-18-2022 09:53 PM - edited 08-18-2022 09:55 PM
@Ooch123 wrote:Hi.
Please help!
That sounds like a network signal issue becasue it's happening to both of you. When signal is weak, you can't do much but use the phone somewhere else. You can buy a signal booster but those can be expensive. Your option might be to swtich to another company that uses a different network. Does setting to 3g only network mode help for calls?
