09-05-2019 05:55 PM - edited 01-05-2022 06:53 AM
If i change my $40 plan to $10 plan, do i lose my 1GB promo?
because my plan will be smaller than before, so i'm worried about lossing that promo.
Thank you
09-06-2019 10:50 PM
they will keep it for you
09-05-2019 06:34 PM
Don't forget to select "change at next renewal" . If you change immediately you'll loose you $40 that you paid for your current plan and will be changed for new plan.
09-05-2019 06:10 PM
Thank you so much 🙂
09-05-2019 06:09 PM
Yea That is amazing !
09-05-2019 06:06 PM
Now that you have it and September 4, 2019 has passed I would think you are ok to change your plan to anything and your addon won't expire until you use it.
Not trying to tell you what to do, but $15 has unlimited texting, and there is no texting addon, so you might want to consider this if you text.
09-05-2019 05:56 PM
@S2_S2 wrote:If i change my $40 plan to $10 plan, do i lose my 1GB promo?
Thank you
Nope. Nice eh? 🙂
