I will travel to USA for one week, which way is easy and cheaper for call and date?
sqcd111
7 REPLIES 7
If you had discovered the Can-US Plan last week or 2 weeks prior, you would have seen that this would have been More Cost effective in the end
Yes you can buy it anytime. But why? Buy it at the airport. Or buy it as you leave the house. The 15 days starts the moment you complete the purchase.
sqcd111
can i buy it now and then use it when I arrive USA? or I have to wait for the last minute? Is the date calculate star from i am in USA
dust2dust
Turn on the roaming data for data. Do you know if your phone has been enabled for volte yet? If so then great. If not then are you able to manually change down to 2G GSM?
The $30 roaming add-on bundle is the only real option money-wise. You get could get the talk/text bundle and 250 mb for a little less but that's not much data unless you don't use very much.
@sqcd111
A cheaper alternative is to only buy data  and use VoIP app TextNow for voice calls and text.  But please note with this solutions, you will have to give your friends the VoIP phone numbers to call and text you
with this way, you will only need to buy this US data add on
Data - US Roaming - 1GB Data (15 days) - $20.00 (15 Reward points)
sqcd111
thank you
Chalupa_Batman
Get the US travel package but do it the night before you leave so you for sure know it's on your account.
US Roaming - Talk Text (15-day) $15.00
or
US Roam-Talk Txt 3 GB Data(15d) $30.00
