07-09-2023 03:32 PM - edited 07-10-2023 09:08 PM
07-10-2023 07:14 PM
They charged me right away. When I had to go get a SIM card, they gave me a credit on my account for $11.30.
07-10-2023 05:17 AM
07-09-2023 03:47 PM
I tried the esim thing recently. It would not work and a big time waster. Go get a physical Sim.
07-09-2023 03:36 PM
hi @Avocado2
sorry, no refund
But what phone you have? what is thr problem? you can always change back to physical sim if it is easier for you
07-09-2023 03:35 PM
@Avocado2 PM is a prepaid provider and does not provide refund.
Most eSIM activation problem can be resolved, maybe try these first
Did you get to the eSIM installation step? Either the app will ask for your permission to do it for you automatically, or you will get a QR code to install yourself.
If you missed the step, there is a QR code in your Welcome email. Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone
Once you installed the eSIM profile, (or If you got passed that step), try to reboot your phone once.
If it still does not connect and if you have any active sim on the phone , disable them (eSIM/Physica sim) or remove the physical sim. Then click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetoosh connections, but you just need to add them back after)
if it still does not work, please open ticket with PM support
07-09-2023 03:33 PM
@Avocado2 For refund / credit you need to contact support
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
VVVVV Link below VVVVV
